#253 - 08/31/00 11:20 PM auto startup
I have found pingplotter great. Is it possible to define a host to plot if started by win 2000 scheduler so that 2 routes could be automatically started. BTW the auto save is a great feature for us. Chris<br><br>
#254 - 09/02/00 02:42 PM Re: auto startup
JMurri Offline
You would have to put two instances of Ping Plotter in your startup group with command line arguments. You can find details on how to do this in the Ping Plotter help or go to <A HREF="http://www.nessoft.com/pingplotter/help/command_line_arguments.html" target="_new">http://www.nessoft.com/pingplotter/help/command_line_arguments.html</A> for information on how to do this.<br><br>
