#420 - 02/01/01 03:21 AM Ver: 2.2
Hi,<br>I have a slight problem here. I just installed ver 2.2. And I notice that in the log fie, the tracert result produces a N/A, and *. may I know what's the difference between N/A and * ?? Furthermore, in ver 2.2, the graph have a vertical line which is gray in color, and may I know what does the gray line represent? I have use 2.03 before and it doesn't have n/a result in the log and there's only black and red lines, no gray lines. Could someone pls assist me<br>Thank you very much<br><br>
#421 - 02/01/01 08:56 AM Re: Ver: 2.2
An N/A is generated in the log file if a sample was sent out but hasn't yet responded when a set up samples are written to the log file. To reduce the likelyhood of this happening, you could reduce the time Ping Plotter waits for a response (Packet Options, Timeout Speed).<br><br>An * is a lost packet. This is a packet that didn't return within the time specified in "Timeout speed".<br><br>A gray line is a period in which Ping Plotter wasn't sending packets, so it doesn't expect any responses. This happens when you pause and then restart. It can also happen if a route changes and a router isn't used for a period, and then the route changes back and it is used.<br><br>
