#1966 - 10/22/07 05:06 AM Multiping fails on start up
Martin Offline
Sometimes Mutiping fails a few seconds after starting and produces an error "dump" beginning like text at end of this message (there is quite a bit more - can send it all to you but probably no point in clogging up forum with a dump!). Does it sometimes and retstarting Multiping normally solves it though occasionally have to restart it maybe twice.
OS: Windows XP Professional, SP2
CPU: AuthenticAMD, AMD AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, MMX @ 0 MHz
Module name: C:\Program Files\MultiPing\multiping.exe
Application data:
VmVyc2lvbjogV2t4M2JuZHFLVlJzYTJGYkt5ZFRPaWM1T2lRNlZpQXN
BQWRWUHlFOEpUQnpaSHQrZHpNa0lqc25JRFpGY25SOWVHcC9SemM3Uj
B4NGFYdHNQMUlia1JTVVg4Tg0KSW1hZ2VCYXNlOiAwMDQwMDAwMA0KL
2004-MultipingDump.zip (103 downloads)
#1967 - 10/23/07 04:06 AM Re: Multiping fails on start up [Re: Martin]
Hi, Martin.
There's a very small subset of people that occasionally get this problem. We're working to try and isolate it a bit more - and we're making some progress on that. It seems to be a third party component we're using - and we're waiting for an update to fix it (hopefully) - probably sometime in November. Once we've verified that this fixes things, we'll probably do an update relatively quickly.
#1968 - 10/26/07 03:49 AM Re: Multiping fails on start up [Re: Pete Ness]
Martin Offline
Many thanks - look forward to fix....
Find Multiping v useful by the way!
