#2040 - 08/17/08 08:43 PM Extension: Allow renaming of hops / target.
Extension Goal:
This extension adds a right-click menu option to any hop on the Summary Graph or a target graph which allows you to edit the DNS Name for that hop / target. This also adds an option to re-resolve the name from that hop (in case you edited the name, then later want to change it back to default).
Required PingPlotter Pro version:
This extension requires PingPlotter Pro 3.20.1p or higher.
Installation Instructions
  • Download the attachment from this post (link near the title). The file will be named "Edit DNS Name.ppx".
  • Trace to a target of your choice.
  • Right-click on any hop or the final destination's hop, then pick the "Edit DNS Name..." or "Re-resolve this hop's name" option.
Other Notes:
If you're using the "Summary Name Override" script, then you'll need to update to the latest version of that script - the old version is slightly incompatible with this script.
Wrap up
**Update (April 15, 2015): PingPlotter v4 has this feature installed by default (no extension needed!).
Edit DNS Name.ppx (2158 downloads)
Edited by Gary (04/15/15 01:22 PM)
#2041 - 08/17/08 08:45 PM Re: Extension: Allow renaming of hops / target. [Re: Pete Ness]
Here's a screenshot of the new menu items:
0 registered (), 11 Guests and 2 Spiders online.
