#4032 - 12/05/23 01:53 PM Help me understand my packet loss?
gtg1881 Offline
I moved to a new house 2 years ago and got an Orbi mesh home system connected to a NETGEAR CM1000 modem. The first year, I had no internet issues. Suddenly, I started getting heavy packet loss while gaming or working. These episode are consistent around 9 AM and then 2 PM.
I am the only other person in the house. It looks like the packet loss happens a lot in hop 1 and when hopping to my ISP. Help!!
[img:left]https://imgur.com/a/aMlHOlm[/img]
#4033 - 12/05/23 01:59 PM Re: Help me understand my packet loss? [Re: gtg1881]
gtg1881 Offline
Here is my share page packet loss at hop 1 and two
#4034 - 12/06/23 12:08 PM Re: Help me understand my packet loss? [Re: gtg1881]
Tyson Offline
Hi gtg1881,
Thanks for sending over the share page. That makes it a lot easier to help you!
The packet loss you experienced during your Zoom calls was first introduced at hop 2. This indicates there was either an issue with the route between hops 1 (your router) and 2 (your provider).
I went ahead and created a share page for you that shows this issue: https://share.pingplotter.com/6r1skB3CWVi. I recommend you send this to your service provider to see if they can resolve this issue. You can follow this guide to help build your case.
Good luck to you!
#4035 - 12/06/23 12:18 PM Re: Help me understand my packet loss? [Re: gtg1881]
gtg1881 Offline
I am no longer seeing packet loss on hop 1 today https://share.pingplotter.com/7mzftX4UgU8
Any reason why this would go away over night?
#4036 - 12/06/23 12:21 PM Re: Help me understand my packet loss? [Re: Tyson]
gtg1881 Offline
Thank you Tyson! Just so I understand, how did you know it was at hop 2 even though hop 1 showed the large packet loss bar. Did I interpret the chart wrong?
#4037 - 12/06/23 07:03 PM Re: Help me understand my packet loss? [Re: gtg1881]
Tyson Offline
The way to interpret PingPlotter is by starting at the final destination, 8.8.8.8 in your case, and work your way back through the route to see if you can identify where that same pattern of packet loss was first introduced.
Since the packet loss you're seeing at hop 1 doesn't really match that at 8.8.8.8 then we can assume they're unrelated. Your router is probably just ignoring the echo requests PingPlotter is sending it when it gets a little busy. This is pretty common especially when the TTL value of those requests is 0. You can read more about this here.
0 registered (), 11 Guests and 2 Spiders online.
