#4052 - 04/05/24 05:49 AM How to monitor internet connection speed in download and upload
cosimo Offline
Hi.
I'm looking for a solution that can monitor continuously the internet speed in download an upload (Mbps) behind my router.
Is Pingplotter the right solution for me?
Thanks in advance
#4053 - 04/05/24 11:53 AM Re: How to monitor internet connection speed in download and upload [Re: cosimo]
Tyson Offline
Hi Cosimo,
It sounds like you're looking for a tool that basically runs a speed test every now and then. PingPlotter doesn't do this but continuously measures the latency and packet loss of your connection so this may not be the tool for you. Depending on what your ultimate goal is you still might find a use for PingPlotter. I recommend you read this article that talks about the differences between speed test and PingPlotter to see if this a good fit for you.
0 registered (), 11 Guests and 2 Spiders online.
