#1035 - 01/07/04 02:39 AM beta 2.45 crash.
Luke H Offline
please check out the following image:
http://www.f2systems.com/files/snap043.png
I got this crash after clicking a couple of different hosts from my saved list, then aborting, then clicking a different host, etc, maybe 3-4 different times. I was experiencing packet loss at the time.
not sure if you will be able to tell anything from the error code displayed but I thought it might help...
#1036 - 01/07/04 02:43 AM Re: beta 2.45 crash. [Re: Luke H]
Thanks for the report, Luke.
There should be a file in your Ping Plotter directory called "pingplotter.rip". Can you send that to beta@pingplotter.com, please? This has more detailed error information in it.
