Hi people.
First of all, thank you for your posts, so yesterday I found the way to fix the "hop 1" issue with WRT54GS routers (i upgraded the firmware).
Now my question. Yesterday I'had problems with my ISP. I presume they were re-configuring something in the main server, and I had awful ping timings. See the picture:
Well, today it seems to be fixed, because I get the 20ms I usually have with my cable internet connection, but I've realized that there's something that might not be good. See the next picture, please.
I mean the high ping readings that you can see in hops 1 and 2 (1 is, obviously, my router) marked with the red oval. As that high readings happens in regular times in both hops 1 and 2, I presume that it's not a problem from my system, since the moment that hop 2 belongs to a router from my ISP. And also, there's a coincidence with that high pings and packet-loss red mark.
What do you think? Should I call to my ISP or it can be a problem in my system?
Thanks a lot!
