#2113 - 05/06/09 11:45 AM Default selection for the Image Type.
Liam Offline
Hi there,
I could swear that back in 2.60 days, it was possible to have the Image type defaulted to GIF as opposed to PNG.
I prefer to save as GIF.
Can we get the option back sometime please?
Thanks and Regards.
Liam.
#2116 - 05/06/09 12:49 PM Re: Default selection for the Image Type. [Re: Liam]
The default file type (png, gif or bmp) comes from the current configuration's auto-save image settings. Even if you're not using auto-save, the File -> Save menu option will look at the auto-save settings to see what image type is specified there, and use that for the default manually-saved image type as well.
Changing that setting should get what you're after (I think). Please let us know if it doesn't.
0 registered (), 80 Guests and 0 Spiders online.
