#2835 - 05/03/16 11:50 AM TCP Trace to port 443
loadblok Offline
I am troubleshooting poor performance that a user is experiencing when connecting to our website, and was asked by a colleague to get a PP TCP trace to port 443. We have looked at the connection with WinMTR but it is not giving us the needed detail. How do I set up PP to do that?
Thanks!
#2836 - 05/03/16 06:48 PM Re: TCP Trace to port 443 [Re: loadblok]
Thanks for using the PingPlotter forums!
What you want to do (for PingPlotter version 5) is go into the engine settings. You can get there by going to "Edit" -> "Options" and under "Default Settings", choose "Engine". Once there, click the Packet Type dropdown menu and choose "TCP Packets (ie: HTTP, etc). Then under TCP Engine Settings, change the TCP Port to "Other" and input 443. Go ahead an click "OK".
Now, when you enter a target to trace to, you will be tracing using TCP packets on port 443.
I hope this helps. If you need any other help with this or anything else, feel free to email us at any time at support@pingplotter.com.
#2837 - 05/04/16 01:08 PM Re: TCP Trace to port 443 [Re: Phillip]
loadblok Offline
Thanks!
