#3254 - 05/23/18 09:07 AM MOS Column bug in 5.5
Tim McKee Offline
There is a bug in the MOS scoring. In moscolumn.js you are using the line:
var percentPacketLoss = LostPacketCount / TotalPacketCount;
which yields a value between 0 and 1. The algorithm you coded actually requires the value be between 0 and 100. Why they wrote it this way is beyond me, but the proper line would be:
var percentPacketLoss = (LostPacketCount / TotalPacketCount) * 100;
I injected up to 20% packet loss stepping up by 1% and the MOS score never dropped below 4.37 with the code you are using. Please correct and send out asap. The correction makes it come out correctly at a MOS score of 2.10
#3255 - 05/23/18 01:31 PM Re: MOS Column bug in 5.5 [Re: Tim McKee]
Hey Tim,
Thanks for putting this up! We've got a dev editing that line, and it'll be fixed in the next release for sure. For now, I'd recommend leaving the change you made - but after version 5.5.12, this will be fixed!
Thanks again!
0 registered (), 21 Guests and 0 Spiders online.
