#670 - 05/12/02 02:23 AM Ping Plotter is not working under W2K server
I can not run Ping Plotter on W2K server with Terminal Server enabled. Once I start Ping Plotter, the CPU utilization screen shows 100%, Ping Plotter screen is not comming up and computer needs to be reset. Does anyone have any experience running Ping Plotter on W2K server?<br><br>Alex<br><br>
#671 - 05/12/02 02:31 AM Re: Ping Plotter is not working under W2K server
Hi, Alex.<br><br>I'm running a W2K server here - and am also using Terminal Services. With version 2.30.1, I don't see this at all - Ping Plotter starts fine and works fine.<br><br>Does it do this from the console also - or just under another session?<br><br><br>
0 registered (), 65 Guests and 1 Spider online.
