#81 - 08/03/99 02:15 PM Timeline Graph Range- Red Hits
gabbey Offline
I have collected ping data from www.lucent.com over several hours.. <br>and when I switch from 3 hour range to 12 hour range on the Timeline <br>Graph.. the red hits nearly completely smear and block out the data. <br>There needs to be a way to surpress or turn off these 'timeout' <br>indicators.<br><br>Also.. a parameter for the timeline instead of fixed 30, 60, 3, 12.<br><br>gabbey<br><br><br><br>
#82 - 08/07/99 04:40 PM Re: Timeline Graph Range- Red Hits [Re: gabbey]
The next version will actually show the average response times in red if there's a dropped packet in the period. This will allow you to measure the performance - AND easily know if there's a dropped packet in that time period. It should be an improvment.<br><br>As for the alternate time periods - you can do it the hard way by editing the time in the .INI file, but ... there's no way to currently from the program pick non-standard time periods. I'll add this to the feature suggestion list, but no promises...<br><br>
0 registered (), 46 Guests and 0 Spiders online.
